Slotted headstock thickness, whats your preference?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=45311
Author:  Steve Jeffries [ Mon Mar 09, 2015 4:42 pm ]
Post subject:  Slotted headstock thickness, whats your preference?
Just cheecking to see what your desired headstock thickness is for steel string slotheads...
Author:  DannyV [ Mon Mar 09, 2015 5:56 pm ]
Post subject:  Re: Slotted headstock thickness, whats your preference?
About 3/32" thicker than the tuners require.
Author:  Trevor Gore [ Mon Mar 09, 2015 6:16 pm ]
Whatever your tuners and binding scheme dictate:
Some headstocks are more flamboyant than others...
Author:  Josh H [ Mon Mar 09, 2015 8:00 pm ]
As the other guys said, it is really determined by the tuners. If you have a jig for drilling the holes keep in mind that it may be designed to centre the holes on a certain thickness of headstock. Check to make sure your jig will drill the holes on centre for whatever thickness you end up using.
Author:  Kamusur [ Wed Mar 11, 2015 4:28 am ]
Nice work there Trevor.
Author:  John Arnold [ Wed Mar 11, 2015 5:45 am ]
I use 3/4", the same as Martin.
Author:  kencierp [ Wed Mar 11, 2015 6:35 am ]
Martin slotted HS's including veneer are .79" +\- a couple .000
Author:  brazil66 [ Wed Mar 11, 2015 7:25 am ]
13/16"
Author:  John Arnold [ Thu Mar 12, 2015 12:48 pm ]
Prewar Martins are 3/4".
I am not all that interested in anything Martin has made since....particularly the ugly squarish slotted headstocks they used in the 1950's, 1960's and 1970's. They are too wide near the nut.
Author:  kencierp [ Thu Mar 12, 2015 1:27 pm ]
OK -- I just measure a few of the brand new "A" quality replacements sitting on the shelf in our shop thought that was pretty accurate information.
